Kyle7R
Looking for some insight before I dive in and start replacing parts unnecessarily; my '09 JK has just a tad over 38k on the clock, it does not see regular road duty due to me working from home quite a bit and having a plethora of company vehicles available for me to bring home (Thanks AT&T ).
Making the most of my most recent 3 day weekend, I took the Jeep out Monday to run some errands, and get the oil changed as it was due; while I was out the check engine light popped on, I had just gotten fuel on Saturday and thought maybe I'd left the gas cap loose as it has happened before. Tightened it when I got to Home Depot, and after leaving the code did not clear. I had the guy read the code prior to changing the fluids and he let me know it was reading a mis-fire on cylinder 2, asked if I had experienced any rough idle or loss of power, which I have not, and still haven't.
He cleared the code, finished the rest of the maintenance and off I went, wondering if it would return. I got it out of the garage and took it around the block Monday morning and the light returned, same code. I figure to start with plugs/wires at least, yet nothing I have found says they need to be replaced anywhere near 40k miles, that they should last to 80k or maybe even 100k before needing serviced.
Any insight to where I should start, or specifics I should look through? I drove it again today to the office, still not experiencing any rough idle, loss of power, knocking noises, gas smell, or smoke of any sort; if there were no light I would not even think twice about anything going on.
Oh, and also I seemed to have thrown a sticky weight and have an awesome little shimmy around 40-50MPH:bleh:. Any shop recommendations in the Houston area that would do a solid balance on some 35's nearing the end of their life cycle :brows:
