Rubi_the_jeep
Hey guys i have run into a problem with my 2000 4.0L TJ. I was off roading with my buddies and the jeep was working perfectly fine. We even stopped at a spot I turn the Jeep off, and went to start it back up and it started fine. Then we got to our campsite. And I turned it off and played music from the jeep while in accessory. But then about 30 minutes later I went back to start the jeep and it just kept cranking. Not starting. I had plenty of volts from the battery, and I did not seem like it was not getting fuel. I happen to have a fuel pressure gauge and I checked the pressure and I was not getting any fuel pressure when trying to start. So we towed it back home and put a new fuel pump on it. And it still cranks but does not start. Replaced the spark plugs, and that did nothing. It’s not the ECU because I had another one lying around that still worked I put that on the jeep and it still does not start. Any help is appreciated thank you very much!!
