COAX Cable Routing.....
atamayo
Installing a HAM radio in my JKU 2014. Antenna will be mounted on a RockHard tire carrier that is not tied into tailgate therefore can't use grommet on tailgate etc. I need to come out rear passenger lower corner where the hub assembly is located. Any ideas?
There's a 4-5 in plastic piece under the corner of the tub there. My last jku I drilled a hole through there and went though then siliconed it in. Worked great. Then just run the wire as normal. You can get to the hole from the tail light pocket inside.
Thank you for the help
Got it installed thanks.
