The body alone or tire carrier alone is NOT a good enough ground. The best ground on your vehicle is the frame. You can run a piece of 10gauge wire from your mount to the frame and it will help out a lot.
Another thing to consider that has been known to be an issue with some radios is voltage. Some people tend to tap into the vehicles wiring in places such as the cigarette lighter but doing so doesn't give the radio the full amount of voltage it needs to operate properly. I always recommend going directly to the battery whenever possible, just be sure to use an inline fuse.
