jeeeep
have you checked the O2 sensor wires for corrosion, proper connection? make sure none of the pins are bent or pushed in, also check your ground connections.Well, I have about 340 miles since the battery disconnect, and it says I have 35 warm-ups and still shows both monitor not complete.
Make sure the battery post connections aren't corroded below the connector - will need to disconnect and cutaway the plastic coating to check for corrosion.
Additional thought, have you swapped the O2 sensors around? also possible you have bad sensors even if new... been there too often lately and wasted a lot of time because it's "new" couldn't be bad already thinking.
