Broken shaft
Jeepin_Jeepata13
Ouch that's a bad one! Looks like it sheered right of and I'm sure the sub zero temperatures played a part in it. Upgrade time!
JKWrang
At those temps, everyone should hibernate instead.
Sent via secret squirrel underground network.
RVC shafts are in the future, just replaced with a set of stock ones to keep me moving for now.
The thing that bothers me about RCV shafts is it moves the weak link to the R&P. That's not really a trail fix.... At least when a shaft goes you can remove it and wheel out.
Sent from my Nexus 7 using WAYALIFE mobile app
SDG
The cold could have defenitly played a part. If I remember correctly torsional strength of most materials is affected by temperature. If it was already fatigued get it "real" cold and its just plain weaker. Or technically I think it becomes more brittle.
Mikes Offroad
$785 dollars Canadian for a set. Still working on a deal for a used set of RVC, just trying to get the logistics all worked out.
