I would leave the bolt off but that's not the right way. Lol
I did the same exact thing when installing my oil pan skid.. they don't need to be tightened down that much, use a torque wrench. An easy out should do the trick
I would also warn people about the inch lb torque wrench from Harbor Freight. Had one I was using on this exact job, seemed to be getting real tight without clicking... put a dif socket on and tightened a skid plate bolt... it never clicked, turned it hard enough to snap the head off in the socket, not a single click!I should note that an "inch pound" torque wrench will make the job A LOT easier to hit the mark and where you know it. :yup:
Guys,
I fucked up today and broke the head of one of the bolts while installing EVO oil pan skid.
After Cozdude pointed me into the right direction on how to extract broken bolt I am still interested In your opinions and tools suggestions.
Ty View attachment 263555
That could be! I just figured it was part of China's finest!In all fairness, a lot of inch pound torque wrenches will "pivot" when you get to the point you need and NOT "click". Of course, I doubt your HF torque wrench came with instructions to tell you as much. :crazyeyes:
All my bigger ones click, and the fancy ones for inch lb at work click too, so just assumed the same.
More than likely, the remaining bolt isn't in there tight and if you try drilling it out with a right hand drill, it'll most likely back out as you drill into it. You just need to remember to drill slowly. If that doesn't work, you'll already have a hole ready for an easy out.
With that said, you're probably fine leaving it as is.
