SaddleTramp
ARB Twin Compressor mounting questions
Hey guys, for those who have elected to do the under seat ARB twin compressor mount location, how/where did you all run your power wires to get to the battery?
Did you just cut off the connector plug or ARB in line fuses and splice back together to get through the firewall?
I know about the firewall drivers side clutch hole and the driver and passenger foam holes behind the dash side caps but curious what the best options are closer to the battery? Also found a hole behind the battery covered by some sealant tape but of course it's about an 1/8" too small to fit the ARB connector through.
Still trying to decide if I want to just do under hood mount or under seat.
Here's a pic of the supplied power wiring. Thank you for any help and suggestions.
![ImageUploadedByWAYALIFE1388969668.578719.jpg ImageUploadedByWAYALIFE1388969668.578719.jpg](https://www.wayalife.com/data/attachments/62/62888-7963bcaa332c6fcd78cdf6fcd98fcc2c.jpg)
Also, anyone have any issues with using MORE bracket and the top of the compressor unit hitting the hood and leveraging it against the hinges when the hood is closed on a 2012+?
