OscarMike2.0
ARB Air Lines. How did you run them? Has anyone set them up with a sPod? Do I need an Air Manifold from arb since Im running 2 lockers?
Thanks!
Thanks!
Thanks!
You need a Solaniod for each locker and one manifold.
You can run the lines through the frame rails to the rear and down past the steering box along the front diff breather tube for the front differential.
Northridge sold me the 2 lock and compressor special. Will I need the manifold as well or will it be included? I also have not seen it for sale. Oscar did you order your axles yet?
I did not order the axles yet. I will be placing the order july 3rd!
Wow, that is rather specific!
That's awesome though! Good for you :rock::rock:
I would also say the switch pros is pretty sweet, if you are looking at the spod look at it too way more mounting options cleaner in my opinion.
I ran a 1/2" diameter flexible sprinkler tubing through the frame rail to the back and then just pushed the blue ARB air line through it very easily. This way if you ever wreck the air line it is easy to just pull it out and slide in a new one. Probably won't ever damage it though with the tubing protecting it.
That's a great idea, I think I'm gonna try the same.
