bmkrinne
Those flats on the axle housing are perpendicular to the pinion axis and 6 deg separation to the caster on the stock housing.  At 92.2 deg on your digital angle finder, the pinion angle will be 2.2 deg up and the caster will be -3.8 deg.  If you want more caster decrease the angle towards 90 degrees, which at 90 deg you would have -6 deg caster.  Need to measure the slope of your garage or driveway since it will affect the angle readings, and adjust accordingly.
Basically take both your upper control arms loose from the axle. Then adjust length on one CA to set caster and pinion angle to 91.5 - 92 deg, then adjust the other upper control arm until you can push the bolt through it.
