Alignment after 1.5” lift
MaddZax
Try to make a long story short - recently went with the same setup the Wayalife Renegade is using (rims, tires, lift, and 1.25” spacers). I had an alignment done the other day, but my steering wheel is just off to the left. The place I went to said they did all they could do. Other shops were saying the camber kit and adjustments are all maxed out and they’re unable to do anything else. Can anyone assist me with this?
I don't see how the 2 would be related, but I haven't lifted a Renegade, I would assume the toe angle would need to be modified to correct that but not sure.
Looking at the pictures in the lift install write-up thread, this thing has a rack and pinion. You should be able to center steering wheel, then adjust toe properly and steering wheel will stay centered. That's how nearly every rack and pinion vehicle is adjusted, I can't see this being any different.
