ABS Module bypass?
I don’t know, but the switch does not require the codes to be cleared.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
My guess would be the vehicle still communicates with the module instead of killing the power to it it instead kills the signal from sensors
wjtstudios
Agreed, that’s about all I could think of as well.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Awesome! Glad it worked! Why do you think it went into limp mode?
Really not sure yet. Had just come off the trail and immediately after I hit the highway, CEL and ESC / ABS, lit up. Checked for obvious damaged lines, and didn’t see anything.
But yea I didn’t know you could create a clean bypass and have everything else work normally by pulling the fuse👍
For now I’ll just add the ABS light to the air bag light on the dash.
jeeeep
daughter just called saying she had ABS/ESC lights and her 2015 JKU felt like it was dragging, limp mode.
Had her pull fuse J6, and she was able to drive off without further issues.
Bought me some time until I return to hell and can isolate which sensor is causing the issue. (y)
