33s on stock jk
engineman1031
I have an 09 jk rubicon. Right now it's all bone stock. I'm lookin to upgrade to 33" general grabbers or at2's with no lift to start since it's the most expensive of the mods I wanna do. But will I have any issues. I'm already running 1.5" rugged ridge spacers so that'll rule out the rubbing. But anything else till I get the $ for like a 2" lift?
BTW it'll be on the stock rims. And any preference for the general tire brand?
You might rub your fenders a bit but other than that you will be fine. If you wanted to you could do a leveling kit
Don't forget he's gonna rub a little on the sway bar at full turn too. Solution = wheel spacers or wheels with less back spacing
I have the General Grabber AT2's on my Commander. Have had no issues with them at all. overall they are a good tire:thumb:
I ran 285/75r16s with no lift for a while and never had an issue. I've now got the 4dr rubicon springs on my 2dr and have plenty of room!
Sent from the Wayalife mobile app
Just got 285s on mine today. Only a little rubbing at full lock, but I also haven't had it off road any.
Sent from my XT1030 using WAYALIFE mobile app
I believe most recommend no greater than 12.5 width on stock JK wheels
Are you running wheel spacers? I'm needing tires but I don't want to buy spacers because gonna get new wheels later.
O|||||||O
JK🇺🇸
O|||||||O
JK
I ran 305/70/16 on my stock steel wheels on and off road. If you leave the sway bar connected the only rubbing you will see is minor rubbing on the sway bar at full lock. I never disconnected the sway bar so idk if doing so it would rub the fender.
No spacers. Planning to go with a 4" lift and 37s come spring, so didn't want to throw more money into this than I had to.
