2014 JKUR small coolant leak at thermostat housing
BigJeschke
Been smelling coolant the last couple of days. Upon checking over the engine I found a little bit of dried coolant on top of the thermostat housing. Looks like there might be some type of vent or plug on top of the housing where its coming from. Anyone else dealt with this before? I did a search but found nothing. Swinging by the dealer in a bit anyway.
Can you take a decent picture of the housing for reference? I don't own a pentastar, but curious if it's plastic etc. If the dealer has to replace or reseal the housing, it would be in your benefit to request a simple coolant flush. I've heard a few horror stories of casting sand in newer engines, though I hope by now that has been fixed, why risk it?
Sent from my LG-D800 using WAYALIFE mobile app
A while back, my thermostat housing had a slight coolant leak at the screw, which dried up. Whenever I scraped it off it would reappear. Took it to the dealer and it was replaced under warranty. To date, after the replacement haven't had that issue come up.....
aldaman
Casting sand or what ever it was, was related to the 2012 and some 2013. Issue has reportedly been fixed for the later 2013 and all 2014
Sent from my SPH-L710 using WAYALIFE mobile app
aldaman
Can someone show where to find that part in the engine bay of my JKU? Last evening while changing my engine air filter, I noticed an antifreeze/coolant smell. I checked my level and the coolant reservoir appeared almost empty (sorry no pic yet).
Also, would really appreciate if someone could show me what would be a normal "cold" level for the coolant reservoir. As said above, mine appeared very low.
Thanks in advance.
We're Saturday today, but I'll give a phone call to my dealer on Monday morning first thing.
BenOA, pull up on the engine cover and look down to the right of the alternator. Mine does appear to be leaking from the screw cap that is pointed to as number4 on the diagram i'm posting. and i tried my best to get a good pic but it's an akward shot.20140802_083247_zpskkffo67s.jpg
Also, why does the coolant in the radiator look pink/red, but the coolant in the overflow bottle looks purple? I have not added any myself as the vehicle only has 1500 miles on it.:thinking:
aldaman
That is exactly what I think is going on in my situation. It's going in next Friday to get looked at and I verified that the dealer has the part on the shelf.
No leaks on mine. Level of the coolant tank is a bit under the lower bulge on the reservoir. Looks normal for now except for the smell.
2013 Rubicon - same issue
I have a 2013 Rubicon Unlimited, same problem apparently, overflow slightly low, been smelling coolant for two months but can't find it, had it in to dealer twice, they think I am nuts..
Just had my 14 Rubi in last week for the water pump replacement (@ 1400 miles) and they also replaced the thermostat and housing because it was leaking just like above.
My 13 smells of antifreeze every once in awhile. Can never find a leak, dealer hasn't found anything either. Since it never overheats, I just chock it up to be a new Jeep thing. But have you guys noticed when the 3.6 is cool, the upper radiator hose is collapsed? like it's under vacuum.:thinking: I've seen 3 2013's do the same thing.
Interesting observation. Can you post a pic and I'll compare it to my JK?
Thanks in advance
There's a dye you can buy that makes the coolant glow with a black light. You put it in when it's dark turn the car on and search with the black light. If you cnt find it right away you can probably check again after a couple days the residue will glow even if it's dried.
Sent from my HTC One_M8 using WAYALIFE mobile app
Thats a little disturbing
I just ordered 2015 Hardrock so hoping don't have that issue you just had, especially at only 1400 miles. Mine has not overheated yet but always odor..
Thermostat housing hairline crack
I had the same issue on 2013 JK, - coolant seepage around the bleeder screw on the thermostat housing. Upon close inspection, where I had to remove throttle body, I noticed a hairline crack in the area where the screw is. Bought new thermostat housing at the dealer for $32.85 not including tax. It comes as an assembly with thermostat, bleeder screw and rubber o-ring all put together. Replaced last weekend in my garage. No coolant leak, no coolant smell ever since.
This just happened to me, crack formed at the plastic mold seam. Dealer wouldn't fix under warranty, but was nice enough to charge me $49 for a pressure test :sigh:, so I'll be ordering an aftermarket replacement.
Are you serious? Brother I don't think your yelling loud enough. This is BS for them to not fix a cracked POS plastic part under warranty.
I would highly recommend you contact Chrysler and have a chat with them.
I had a slight coolant smell, was out of fluid in the reservoir except for a dark sludge crud in the bottom.
I took it in to the dealer for a check up and a flush out, at first they wanted me to pay for everything. Even with only 7100 miles on the vehicle, and an extended dealer warranty.
After a call to the nice lady at Chrysler I was given a case number. The repairs were free and the tech even found out I had a cracked radiator. (Sorry I was not told or shown where the crack was)
They flushed my system out good and filled her up with new OAT. It was low after a few days so I bought a gallon of OAT and a gallon of dist. water. IT took about 1/4 gallon to get the reservoir up to the bump out thing on the side.
So far so good.
