1998 Jeep Wrangler TJ 4.6L Stroker
IceKnight
I think its time to sell my Wrangler. It was a frame off build over a few year period. The thought of selling to start a new project sounds quite entertaining, so here it is. This is not something I need to sell so if you are looking to low ball don't bother wasting your time or mine.
The build itself can be seen here, http://wayalife.com/showthread.php?15697-The-Uncharted-build
So the details: 1998 Jeep Wrangler TJ Sport current mileage on motor ~ 8,500 current odometer reading 156,540
Frame Completely stripped, motor mounts, front track bar mount, steering linkage mount, Rear control arm mount, transfer case nutserts, reinforced rust prone areas, coated inside and out with Rust Bullet
Motor 4.6L I-6 stroker, 4.2 crank, block bored out .30 over, Icon IC944 .30 pistons, Comp Cams 68-232-4 cam shaft, Mopar performance valve springs & retainers, Mopar performance head gasket, ARP head studs, Melling oil pump, 62mm throttle body, Ford 24lb fuel injectors, FAL electric fan, aluminum radiator, header, hi flow catalytic converter , Banks cat back, gaskets, bearings, push rods, rockers, timing set, distributor, all sensors, hoses, copper freeze plugs, Brown Dog motor mounts, port and polished runners on head along with gasket matching, 3 Angle valve job, oil pan, Amsoil Breaking Oil for the first 750 miles, Amsoil 10W30 since
Transmission / Transfer Case Advanced Adapters SYE, Advanced Adapters braided stainless steel clutch line, Novak transfer case shifter, Tom Woods rear drive shaft, Amsoil transmission fluid, Amsoil ATF for transfer case
Suspension Old Man Emu 2.5 HD Springs, Old Man Emu L series shocks, JKS upper and lower control arms, JKS Quicker discos, TNT front track bar, Rokmen .5 body lift, Rokmen bump stop extensions, Rokmen rear spring relocator kit, Factory bump stops
Axle front 2000 HP Dana 30, 4.10, 16" Vanco big brake Kit, Stainless steel brake lines, Solid differential cover, Lube Locker gasket, upper control arm bushings, Gusseted lower control arm mounts and upper control arm mount
Axle rear 1999 Ford 8.8, 4.10, Artec truss, Yukon Ultimate 8.8 alloy axle kit, Ford racing LSD clutch packs, Solid differential cover, Lube locker gasket, Currie 8.8 brake line kit, pads, rotors and calipers
Armor Rokmen HiLine tube fenders, stryker corners, transfer skid plate, gas tank skid, rocker guards and power steering skid, Poison Spyder BFH II rear bumper, Mopar front rock bumper
Recovery Warn M8000-S, front and rear Shackles
Wheels and Tires Black Rock 15x8, Goodyear MT/R Kevlar 35x12.50x15
Audio Alpine head unit, Alpine 300 watt amp, 8" Pioneer Sub , 4" Components Front, 6.5" Co-axle Rear
Other items that will be included - Artec Dana 30 truss with new joints, Rokmen rear bumper/frame tie-in's, Replacement front led indicator lights, Replacement Amsoil air filter, Just had a fresh Amsoil oil change with filter, other misc. items from the build and factory parts will be included.
Any questions please feel free to ask.
Price is $14,750 obo
