mchrisovergis
Those who are running the EVO DTD w/ Cantilever set up, where are you placing you're evap canister? I'm also running and LS3 so the muffler is larger than normal too. Pictures please'
Like you, I have an EVO lever and an LS so I made my own relocation brackets and installed the EVAP over the rear axle.
Thanks for sharing. Are you mounted to that crossmember? Cant really tell due to the cantilever in the way.
I made brackets that the factory EVAP bracket mounts to and extend out to the old spring perches. I have the brackets bolted to them.
Clever you are, thanks for the idea!
No LS Yet for me but mines still in the stock location. Custom dynomax exhaust wraps right around it and dumps before the axle.
No issues with contact either I assume?
Also, since you have an LS, do you have any pictures of where you ran the 2 into 1 pipe from the motor? Mine came very close to the last tank. We wrapped it concerned about heat.
Yup, that's how Rubicat is setup. Stock location and still running the stock skid.
