boardsurfer
Ok, here's the deal. I have a SwitchPros installed with a handful of accessories running through it. Love love love it. The only downside is that it leaves a little to be desired when it comes to actually hooking things up. There's just a crapload of wires to connect together. My current solution is a small box velcro'd to the top of the battery that has watertight plugs where the wires go through. Inside there is a terminal block where all the switchpro wires are on one side, and the accessories on the other. The ground leads are going to the bolt on the body panel on the left there.
The original plan was to duplicate the positive side setup for the ground wires, but the box I bought didnt have as much space in it as I hoped.
So I want to clean this mess up a little more. I am going to order a bigger box that will fit two terminal blocks in it and run all the ground wires inside. The catch is I only want one ground wire coming out of the box. I'll use something like this on the terminal block:
THE QUESTION: I assume since all the grounds will come out of the box on one wire, it will need to be a little more substantial, but how much? As far as I can tell, 10-awg is good for 30 amps which is what the compressor draws. But that little metal doo-dad is only good for 10a. Am I completely barking up the wrong tree? Please help me not burn my jeep down.
