It is not taller. My 50qt is a little under 9 inches off the floor. You can see where it stops. I ran a marine grade DC outlet to the back of deck, the fridge plugs into that.Thanks Gang. Keep it coming please. I know the 37 and the 50 have the same footprint however how much taller is the 50? Is it taller than the JKU back seat? Also, how are yall gettin power to your fridge?
didnt get the cover for mine yet .. second shot will give you a good idea of overall height put the 5 gal water can in front of it as you can see its about 2"tallerIt is not taller. My 50qt is a little under 9 inches off the floor. You can see where it stops. I ran a marine grade DC outlet to the back of deck, the fridge plugs into that.
This is great Thanks Gang! I think its the 50 quart is the winner. Do any of yall use the ARB slider? Its expensive. I wonder if it is worth the coin?
Dometic makes a slider for half the price. I plan to get it eventually.This is great Thanks Gang! I think its the 50 quart is the winner. Do any of yall use the ARB slider? Its expensive. I wonder if it is worth the coin?
That's great. I'll look for it. Thanks
Here's some info on the slide option Jackal is referring too. I went with the 50 qt. You can the slide towards the end of my write up. Haven't used the slide yet off-road, can say it is well made FWIW.
DIY JK Trunk deck and security enclosure
https://wayalife.com/showthread.php?t=45451
