4:10s is whats standard on most the rubicon's and thats what you want; with that you can easily run up to 35s. Check the sticker on the ones you like it will say the ratio. And you say "what rear gears" like it can be different from the front diff but it doesn't work that way on a 4wd vehicle the front will be the same. They call it rear gears on the website because there are 2wd wranglers :naw: but rubi's are 4 wheel only.I've finally decided to get a 12 JKU Rubi. I'm going with the automatic trans. The one thing that I'm not sure about is, which factory rear gears to get. I would like some input from you guys. Thank you in advance. My apologies if this is a dumb question.
CDL
CDL
CDL
I didnt think 2wd was an option in the wrangler any more :thinking:
