cozdude
Guy with a Red 2-Door
I it'll be a good start to the bar. [emoji631][emoji1360][emoji322]
That's gonna be bad ass!
Nice! Are you going to mount it or turn it into some piece of furniture?
Awe shit second time the FC appears on JP mag!
It was a cool article. I got it in the mail yesterday and flipped right to it!No way, that is sooooo cool!! :thumb:
No work to the FC, but I did start it the other day.
I also picked up some FC Art for the living room. Thanks for picking it up Ray!
The front has never had shocks as long as I've owned it. So I bought some new shock bushings and installed a set of factory JK shocks on it. They are close enough to the right length, so it'll work !View attachment 203542
New lines compared to factory Length..
Brakelines on!
Still need to pick up a brake switch and bleed them..
Hey piginajeep, did you have to modify the jk shocks to fit your FC mounts? I have a set of rubicon shocks that I'd like to put on my FC -150... your suspension setup looks similar.
I just pressed in new hour glass bushings on one side, and drilled out the other side for the larger stud on the FC.
These work fine until I finally decide to buy the right ones, but they are stiff enough for the FC IMO
The rubi shocks or the OEM aren't stiff enough? If you're referring to the current stance in the pic, it's soft alright. The original shocks are still on it and the leaf springs look like a shitty deck of cards. The passenger front spring snapped off at the bushing
