View attachment 236821Installed my JW fog lights.View attachment 236822I had to remove the grill and un-mount my winchView attachment 236823added in the JW connector into the factory wire loomView attachment 236824Even went as far as to drill a hole in the bottom of the bumper to access the adjustment screw for the fog light. Crazy, I know....
Reinstalling the fogs on my LoD sucked. Those little screws were nearly impossible to get to, a u-joint adapter is your best friend though.
Looks good. Our JK has that same bumper. A couple of those little light bolts are tricky to get to.
Yea, those little screws that hold the fog lights in definitely suck. I did in fact use one of those u-joint adapters. It helps to wrap a bit of electrical tape around the joint to help stabilize it by making it stiffer. The whole job only took 5 hours! [emoji23] [emoji106]
Bed lined my front grillView attachment 236908
Looks great! I'm curious what you ended up using. I've done this several times now (different jeeps) and used bed liner spray, flex seal, and Plasti dip. I've found the Plasti dip looks the best for a straight matte look and holds up well. However, it doesn't have the bedline texture.
Shortened my rear JE Reel driveshaft by 1-1/2". It was binding at full droop with the PR60 / Evo Lever combo. Pushed the cap right out of the slip yoke.
:grayno:
Dave
