Opinions on AEV tire carrier
GraniteCrystal
Been looking for a tire carrier once I go to 37s. Looking at Evo hinge mounted, CC hinge mounted, or the AEV frame mounted.
I like that the AEV also can carry a shovel, a fuel tank, and has mounts for lights, CB antennae and hi-lift/pull-pal. But, it's got to work well as a tire carrier first and foremost.
Anyone have first hand experience with it and have some feedback?
Build thread: http://wayalife.com/showthread.php?t=32769
I have had the CC hinge mounted tire carrier for almost a year. It's holding a 40" toyo on a Spyderlock so around 145# with no problem. I have run the Rubicon and a bunch of Colorado trails and it continues to impress me!
I have one. It works.
It rattles and squeaks which requires torquing things down periodically. Other than that no real big complaints. Some people don't like the offset look. It doesn't bother me. It's less noticeable the bigger the tire.
I still need to get around to mounting an EVO facia and D ring mounts to finish it off.
There us a place in town asking $1400 for one. Off of a salvaged jeep. They said has bumper, carrier and fuel caddy on it. Need place let me know.
I love mine. The only thing is that your rear view mirror becomes kinda of an accessory since the tire is moved higher up and it also depends on the size of the tire and if you have the fuel caddy.
I have had no problems with mine, I seriously recommend. I was originally going to get the terra flex HD carrier and decided against it. Im happy I got the AEV tire carrier instead.
The AEV tire carrier is what I would run. The EVO hinged mount is still just mounted to the tailgate.
That's my thinking as well. If I want to use it to haul gear (shovel, gas/water, maybe even a little cargo rack, etc) then frame mounted has got to be a better choice right? Thanks Eddie
Getting all that onto the frame is definitely what I'd prefer to do.
AEV tire carrier and EVO fascia. I love it. It's a tad stiff when opening the tailgate currently, I need to add some grease to the spindle again.
Now THAT is a clean setup right there!! Nice job :thumb:
I currently run the AEV bumper/tire carrier. Includes cab antenna and rigid trail light on the mast as well as fuel caddy and shovel on the carrier. No issues. Very clean look. Very solid. Running 37s currently.
Does anyone know how difficult it would be to change the lug pattern on the carrier if you already own it?
