Driveshaft grease.
Wethy
I put in a new Adams driveshaft a while ago and it's coming up on 5K of driving So I figured I should grease the zeros on the shaft itself. I did a quick search on the ole Google machine and have seen Lucas Oils "red N tacky" and a few others, but was curious what some of you guys are using for grease on your aftermarket drive lines. Thanks in advance
I use good old high-stress black grease with Moly lube in it. Or maybe it's called Molly lube. I've been using this type of grease as long as I've been working on cars and trucks. No problems for me...
Here's what I use. If someone has something better suited for jeeps specifically, I'll switch over, but for now, this does the job. :yep:
Edit: oh, and the Lucas gun leaks like an SOB. FYI. I just picked up a Lincoln 1144, it seems to do a better job at not leaking grease all over the garage. :yep:
