Yes, that was EVO1's old stock dash in 2010, customized on the passenger side for the Lowrance Chart Plotter/GPS. This was done for the first year it was raced in the King Of The Hammers.
I'm going to revive this old thread. So for the guys that have the slabs, do any of you run spacers? I know that it will add stress but I rub on passenger side shocks at compression an a little turn. So dilemma is run spacers with added stress or rub on my triple bypass? What would you do?
Get 60's. :thumb:
I had run 1.5" spacers with my slabs. A bit more wear on joints etc but it will be fine. Just have to be a little bit more aware of brake calipers being exposed.
I would love to know if these are still purchasable.The rarely purchased, but still great looking raw aluminum ATX Slab....
Ordered slabs and should be in next week. I like the black look and plan to paint the rock rings but have a question. Should I paint the entire ring or just the visible side? Would painting the inside impact the seal with the tire?
I only painted the visible side as well. Mostly because it was easier, and I didn't see a reason to paint the inside. Love the look!
Best close up I have
Those look awesome. What paint brand and color did you use?
I just got w set and all ready for air.
Anybody know if an ARB twin air compressor can generate enough pressure to set the bead??
Yes it can, soap the bead first.
