EVO front bumper and later down the road
EVO 1/4 pounder with bull bar
Does anyone know if the PureJeep light bar that was on Rubicat is a direct bolt-on. Will it work with the EVO shackle mounts? Are there any other options out there that may work? The wife drives the jeep to work almost everyday and isn't really excited about the stinger. Want tot see if there are any other options besides running nothing but the bumper.
Thanks
I had a similar problem as you are about to when installing your 1/4 pounder after relocating my vacuum pump if you use the EVO relocation bracket. I used the EVO relocation bracket, and with my e-disco motor flipped in the direction that yours is, the motor would hit the drag link while I was turning right. My solution was to flip the motor in the opposite direction, with the plug on top. The spacers from the EVO relocation bracket now help to hold the motor out of the way of the radiator. I still need to bend the transmission line out of the way, but here is how mine looks now. ImageUploadedByWAYALIFE1410152469.515314.jpg
Nice! I didn't get a stinger yet but Overlander said to get the bolts in the top you have to trim the frame end plate. Strizzychris probably has it in his write up too
Yep, and it's a huge PITA. I didn't want to pull the bumper off so I ended up sticking a dremel tool in there to shave off enough of that end plate to fit the nuts.
Thanks
When you take that stinger off PM I may be interested in it. I also have a stubby with a bull bar I'd swap you if that sounds like a possibility. I think retail was 550 +tax and shipping.
Thanks
Yes, the PJ bull bar is direct just like Eddie had back in the day. Not sure of any other options. Maybe give drew a call tomorrow at the shop.
I had a similar problem as you are about to when installing your 1/4 pounder after relocating my vacuum pump if you use the EVO relocation bracket. I used the EVO relocation bracket, and with my e-disco motor flipped in the direction that yours is, the motor would hit the drag link while I was turning right. My solution was to flip the motor in the opposite direction, with the plug on top. The spacers from the EVO relocation bracket now help to hold the motor out of the way of the radiator. I still need to bend the transmission line out of the way, but here is how mine looks now. View attachment 99336
That's great information, thanks so much! I will find out Wednesday when my stuff arrives.
If you ever decide to get the no limits, this is about right for me. Knob it's easy to get too. If you rotate it too much, the plug is on the transmission line. You might have to bend it.plus getting to your knob Will be harder Here is a side view of how I did mine. With 37" tires and coil overs I'm sure you'll be fine.
I took off my perfectly good working motor for the evo no limits. Now I have no worries about it not working or messing up. Seen a ton of People have issues over and over. Probably going to sell it.
I did the same thing for the same reason. Back to "old school". Wish Jeeps came with the manual hubs still...
I just tried this and am not sure the winch will fit with the plug in the up position. I'm really unsure on what to do here. Should i rotated it like the stizzychris write-up or rotate the plug up?
Picture with it up
Just flip it with the plug on bottom
(I feel adding more confusion. and a contradictory view, to an already WAY too long discussion about this plug/flip was the only way to go at this point!)
flip it the way it will allow the winch to fit - set your winch in place and see if it makes contact.
Your right, should be flipped in bottom
