New plugs, wires and coil. Had an engine code that said misfire in cylinder 3 so figured I'd go ahead and do this. 82k miles so hope this'll be good for a while. Passenger side was a bit of a pita to do but not terrible.
This was done a few weeks ago at my wedding just got the pictures back now. Mod/ mess courtesy of my family, even my 5 year old cousin was involved ImageUploadedByWAYALIFE1407124148.591763.jpg
Currie RJ60 Dual caliper bracket.
breaking improved greatly but peddle feel is still soft. I am hoping the bigger bore cylinder. will greatly help that
Installed wheel spacers this past weekend. Made the stance a little wider. Here are some before and after pics.
Before
After
Next weekend will be the Dynomax exhaust.
R/
Will
<img src="http://wayalife.com/attachment.php?attachmentid=94252"/>
<img src="http://wayalife.com/attachment.php?attachmentid=94253"/>
<img src="http://wayalife.com/attachment.php?attachmentid=94254"/>
If it doesn't, try changing the rubber parts of the brake lines with braided steel - works great on bikes to get rid of line swell caused sponginess
Confirmed my order ....I will be getting the gear installed in Oct..... EVO high clearance long arms / Front DTD / Rear leveler DTD, I will also be doing a full Poly cage at the same time . I'm looking forward the this phase if the project to be completed , and should have completed it long ago.
Sent from my iPhone using Tapatalk 2
5 Tire rotation
When I bought my Wheels and Tires I never had them balanced so for piece of mind I thought I would have them balanced since I need a rotation anyways.
Result: 4 of the Tires where perfect and the other was only 2oz out!
Even better Discount Tire gives me the new customer discount....... 5 37" tires balanced with a 5 tire rotation. no sore back all for $25.00
WTG Discount Tire, ATX Wheels, Nitto Tires :rock:
Just picked up my wheels and tires :)
I'm suppose to install my suspension in 2 weeks, but I really want to get these mounted... lol
Sent from my NSA monitoring device... Using the WAYALIFE mobile app
