"skeptical on welding" as in they may not be as strong as bolting them on?
Think he meant he wasn't sure he could do the welds
Yep thats what I meant. Im sure theyll be durable haha. I have a friend who has some welding experience, so skeptical as in taking it to him or should I just take it to a professional whose installed em before. I have no worries about the capabilities of these things.
To save time =$ you probly want to have layout and temp support figured ahead of time before taking it in. I would recomend pre mouning and using a few of these K5 self tappers thru rosette holes at hom
e first. Then remove for drive to shop then re mount. If welder is not going to have to worry about clamping this together it should save a bunch.
These screws are designed gor 1/4+" steel and will go thru frame like butter
Where could I find the tappers lol I've been to ace hardware and Home Depot, no luck
Since the finish is raw steel, I plan on spraying with Bedliner. What should I prime with & what's the best bedline product?
Several coats of self-etching primer. and rustoleum bedliner spray has worked best for me.
