What about the rear bumper? It isn't listed on the spec sheet.
Looks like a poly performance bumper. Just a guess
I was wondering the same thing about the headlights! Too tough to tell from the angle.
The front axle is $12,500 and the rear is $11,000. Search "Mopar Portal Axles" and click on the allpar link. This is the best breakdown I have seen for the exact same set that seems to be on this Jeep.
Looks great! This is my favorite vehicle so far. Any idea if it will actually become a reality?
Really digging the color
ChrisB said:This is mopar accessories, Meaning you can build the jeep from the Mopar parts catalog...
1BAMFR said:Badass Jeep....
Can someone explain how you get 5.5" of lift from the portal axles?
are those jw speaker headlights? and anyone know how much the portal axles go for?
From what I understand, the hub is actually lowered which essentially pushes the wheels down away from what would be the center of the axle. This essentially naturally gives you a lift as the tires are moved away from the body. If you zoom into the photos you'll see how the hubs appear offset and the diff housing is so high off the ground.
