1941 Willy’s Slat Grill
It was just the hood that changed it.
Here’s AI’s version,
I didn’t want to ruin her photo by taking it out of the album.
For these young guys, that’s a photo album.
Next up, the previous owner to Roger was a WW2 vet that served in Germany during the war.
Roger was a Korean War vet, Airborn unit.
View attachment 431455View attachment 431456
Amazing stuff. I think it’s great that not only are you restoring an awesome piece of history, you’re restoring its history as well. Nice job! 👍🏻
Speaking of red lock tight, I was driving the 41 to the store today, and the damn T case shifters fell through the floor rattle around and shot out the back.
Luckily I was able to retrieve all the parts, the set screw loosened up and let the pin back out. It’s all back together with lock tight, it’s blue though. I need it to come apart in a couple weeks. 🤣
I’ve been ordering a collecting parts for the transmission rebuild, I’ve finally recieved all the parts. I’ve ordered 2nd gear twice and it’s still machined wrong, so I’m trying to find NOS supplier currently. It doesn’t fit the syncros.
I will say, what I thought I was going to spend for a transmission was wildly under budget, 🥹🤣.
Holy hell these things are not cheap.
I decided to start trouble shooting the wiring for lights , and broke down the switch for a little restore. These are pretty basic to break down and clean up.
img_2884-jpeg.432308
As I was pondering why I decide to deal with this wiring mess, I was digging into the glove box and found a replacement end for the light switch, these have small button releases on them to stop troops for accidentally turning the lights on, as lock would have it. The previous owner must have found one and left it in the glove box
I did a little more wiring today, Cleaned up what appears to be an original black out switch. The board is starting to seperate. But it’s back working.
I need to order a brake light switch and 12v alternator. Both are shot. I’m pretty confused on this wiring mess. Someone started swapping it to a 12v, but left the 6v voltage regulator in it. The 6v Jeep is wired with positive ground where this one is a mix.
For now it’s going to a 12v system, until I have a shop to rewire it all property and put it all back to 6v. IMG_2904.jpegIMG_2905.jpegIMG_2906.jpegIMG_2907.jpeg
Well I worked out of town this week, and finally got a chance to work on the wiring some more.
I replaced some shitty fuse block with a factory reproduction block, swapped out the brake switch with one from a Harley. I found the brake switches from Summit are garbage and work half the time. The Harley switch is the same thread pitch and works every time.
The brakes light, and rear black out lights work great, the front blackouts still don’t, so there’s more troubleshooting on those .
This wiring job is just to get me functional lights until I can replace the entire harness and gauges with factory reproduction parts.
I learned the brake lights only work with the headlight switch on. Must be another safety feature for combat.
img_2948-jpeg.432543
