rich67
13 Wrangler 6 speed. Clutch and all related parts replaced about 2000 miles ago. Starter replaced 1000 miles ago. This rattle started up about 200 miles ago. Jeep shifts fine, no problems going into gear, shifter feels solid with no extra play (more than expected from a Jeep, anyway). Noise comes and goes- sometimes it will be quiet as a mouse, then when you start the Jeep up after its been sitting for a couple hours I get this.
Almost sounds like loose linkages, but I am not sure if the sound is traveling and resonating INTO the gearbox area from somewhere else. It's noisy outside the Jeep also. Not RPM or gear dependent. Makes the noise in gear, out of gear, clutch in/out...etc. Seems worse after going through water.
This is not the typical 6 speed rattle- I had that for a long time when the Jeep was new, and it sounded like dice rattling around in a tin can. This sounds like metal rattling around and striking more metal. Thank for looking/listening. Any direction I can get would be good.
No CEL codes except for the typical EVAP small leak, knock sensor circuit, and speed control sensor codes that I clear.
