U-joints WILL bind at steep angles. rzeppa joints will have NO bind issues. IF you have vibrations, it's because your shaft is out of balance OR the bearings are starting to go bad. Could be that the steep angle that it's now sitting in is causing that to be more pronounced. Either way, the CV boot will be in a constant state of pinch and will fail sooner than later. So, a new shaft will be something you need anyway.it was fine before the lift, I was thinking the OEM drive shaft might be in a bind now and a new shaft with a CV joint might be better ?
thats what Im planing today (-:Maybe remove the front drive shaft and drive it to see if the vibration is gone.
www.wayalife.com
