QUESTION for Gladiator Owners...
If you have a Jeep JT Gladiator, could you please do me a favor and let me if the following holes on the back of your the bed, just below the rear window, are open or if the lower ones have a threaded nutsert in them.
The pic you see here is of our Gladiator Rubicon (back when it was brand new) and the lower holes have the nutserts in them but I have also seen some Gladiators that don't. Needless to say, I'm just trying to see if more have them or don't.
I appreciate your help and thank you.
Eddie
Thanks for chiming in. ALL 2021 and up do not have the nutserts? If so, I didn't know that.
It was a big to-do on that other place I told you about.
The big problem with it, a LOT of the bed cover manufacturers designed covers to work with those holes. Since Jeep didn't notify anyone about the change (among others) aftermarket was caught off guard.
LOL - okay. I appreciate the intel. That is very helpful.
Couple of other things that changed on JT's.
TPMS: 2020 and back will work with older versions from JL's and JK's. 2021 and up will NOT mate up with TPMS from older vehicles.
ECM/PCM: 2020 and back it is possible to support power adders, superchargers and turbo chargers. 2021 and up will NOT support power adders, not possible to write to ECM/PCM.
Just in case anyone needed to know.
Mine was built in 2019. Lower hole threaded and upper is open. I remember when I put on the cover, rugged ridge included a well nut for the upper hole.
Thank you for confirming things. Our JT is a 2019 build too and it has the lower well nuts but the ACCUAIR does not and it's a 2022.
My 2021 Mojave did not have nutserts, I remember the open holes and wondered why
Okay, that's good to know. I think the ACCUAIR Gladiator is an Overland and it has a lot of nice features but it didn't have the nutserts. I just wanted to make sure that having them or not wasn't model specific. So far, it sounds like it's a model year thing only.
I'm gonna guess there are a LOT more Gladiators without the nutserts than with.
Being that I am currently Gladiatorless, would someone be kind enough to take a measurement for me? Specifically, I need to know what the distance is from the center of the lower hole to the edge of the bulkhead where it starts to bend away.
I really appreciate your help, thanks!
Got a few things working against me, but, from the center of the bolt in that hole to appx where I believe that body line is (spray in bed liner) I come up with 3/4" or 19.05 mm.
