How does that product feel once its cured? Is it similar to bedliner or is it more like a rubbery undercoat? Do you know if it UV fades to grey like other products?It was a 2 step application. One for sounds deadening and one for thermal protection. Went on pretty easy. First coat dries grey and the second dries black. Looks like bed liner.
View attachment 365320 View attachment 365321 View attachment 365322 View attachment 365324 View attachment 365325 View attachment 365326
Once cured it is similar to bed liner texture. I notice that it was quite flexible when it dried on parts of the plastic I used to wrap the Jeep. I’m not sure of the UV protection.How does that product feel once its cured? Is it similar to bedliner or is it more like a rubbery undercoat? Do you know if it UV fades to grey like other products?
I’m going to run ProRock 60 front and back. I went with 37” on Trail Ready bead locks.Awesome build! What are your plans as far as axles, suspension and wheels/tires?
I may end up getting 40’s when it’s all done. Just not thrilled with 3.6L power turning all that weight.Damn this is going to be a hell of a build. Why not run 40s?
You actually have the 3.6 L and honestly it’s fine turning 40s with 5:38 gears. At High elevation, it does dog down a bit, but it still turns the 40s. Would I love to upgrade to an LT or 6.2L, absolutely, but I will do it because it’s fun, not because it is needed.I may end up getting 40’s when it’s all done. Just not thrilled with 3.8L power turning all that weight.
I see you’re run 40’s with the stock motor, any complaints or does it do all you need?
Does the 3 inch larger tires make up for any power loss?
Fixed to 3.6L. See I’m already trying to get more powerYou actually have the 3.6 L and honestly it’s fine turning 40s with 5:38 gears. At High elevation, it does dog down a bit, but it still turns the 40s. Would I love to upgrade to an LT or 6.2L, absolutely, but I will do it because it’s fun, not because it is needed.
I will say 40s on the trail is by far worth the power loss especially out where you are.
Awesome!! I wish it was that easyFixed to 3.6L. See I’m already trying to get more power
