Rough idea of how much that thing weighs?Making some pretty good progress
View attachment 365148 View attachment 365149 View attachment 365150
They are fun. I’ve always wanted one but they are limited I think. A direct heat cooker or probably the most versatile/useful. I plan to make one after this one is wrapped up.Not that I'm the most experienced, but I really like this style smoker. Nice work it's looking great.
My back will be sore for a few weeks from lifting that firebox if that is any indication.Rough idea of how much that thing weighs?
Doing some quick math, the 1/4” is about 10 pounds per square foot. That would put the firebox at about 170. The tank is 1/4” as well and probably about 200lbs. I would guess it will be at least 500 pounds or damn close to it.Rough idea of how much that thing weighs?
Get some wafer wheels for your 4" grinder. Like a knife through butter. Make a straight line on the steel using a square, start your cut straight and ziiiiiiiiiiip you're through.It’s 1/4” it’s not going to distort/warp. But I did put angle around it to clean up the sloppy cuts. It was not easy cutting the 1/4” without the proper tools. I’ll order it to the size I need next time. I will probably add some bracing on the inside of the firebox door as a just in case. If that warps, I won’t be able to close it. If for some reason the other warped, it would effect the cooking process.
Dafaq is a wafer wheel?Get some wafer wheels for your 4" grinder. Like a knife through butter. Make a straight line on the steel using a square, start your cut straight and ziiiiiiiiiiip you're through.
Thin cutting wheel for side grinders. They are made for cutting metal.Dafaq is a wafer wheel?
For an even smoke without hot spot on the right and cold on the left you'll want to put a deflector plate above the firebox opening to deflect/spread the heat
Meh not necessarily.For an even smoke without hot spot on the right and cold on the left you'll want to put a deflector plate above the firebox opening to deflect/spread the heat
I’ll check it out. ThanksThin cutting wheel for side grinders. They are made for cutting metal.
Are you going to reverse flow or cross flow?Making some pretty good progress
Cross. I want to like reverse but I don’t know. I’m not sure why it’s necessary. Although I have thought about a reverse or double reverse cooker for cold smoking. Not sure if it would work or not.Are you going to reverse flow or cross flow?
Not necessary at all to reverse flow... I think it does make it a little easier to keep temps down on the fire box side.Cross. I want to like reverse but I don’t know. I’m not sure why it’s necessary. Although I have thought about a reverse or double reverse cooker for cold smoking. Not sure if it would work or not.
Yeah for sure but also makes it hard to get temps up on cold days or large cuts.Not necessary at all to reverse flow... I think it does make it a little easier to keep temps down on the fire box side.
That’s a heck of a project Adam, looks greatMaking some pretty good progress
Looks great man... I wanna see what you come up with for the firebox air inletThat it is. View attachment 365186
On the cook chamber side or the door side?Looks great man... I wanna see what you come up with for the firebox air inlet
