JK Destroyer Sliders
SSRuger
Did the design change on the Destroyer Sliders? It looks like they are now frame mounted instead of body mounted.
Any pics of the installation?
Sure. Went out and took a few for you. These should work for now.
As installed. Everything's 3/16" steel. Nice surface finish.
If you look down the length, you'll see there's at least an inch between body and rail all the way along. There are zero fasteners going to the tub.
Couple shots of the front and rear mounting points.
This last shot is looking straight-up into the recess. They're using 2 of the existing frame mount bolts along with the flange that requires the installer to drill a hole to accommodate.
Overall, seems to be a very robust installation. This week we'll be at SMORR...plenty of things to slide-pivot around with them.
So, as you'd expect, I'm happy with them thus far. I wanted sliders with steps. These meet the bill so, when we do a lift, we have a 'bit' of relief with the inset step. Cosmetically they turned out about as I expected; hard when looking at things online.
Incidentally, shipping weight 110lbs. Figure ~10 for box and foam (typical high-quality LOD shipping packaging), and it's another 75 lbs net on Stitch (100 lbs - 2 stock sliders).
Time will tell as for the rest.
pretty badass now that they are frame mounted for those that need a real step.
How did these hold in SMORR?
Sent from my SM-G955U using WAYALIFE mobile app
