Best DIY jk mods??
Nice looking table, but pressure treated lumber? I wouldn’t use it as a cutting board or put food directly on it. It’s well documented that you shouldn’t use chemical treated wood for cutting boards or counter tops. Just FYI...
I’m coating it with polyurethane to seal it off
2009 JK sunset orange, inner tub line-X'd, 35's, Cage type roof rack, bed lined inner hard top, 12k winch, Tepui RTT, and other overpriced pieces of jeep stuff
Bump....
DIY Budget Boost: If you have a shitload of time, access to materials, engine lathe and knee mill then maybe you too can make your own lift kit.
Coil Spacers and Bump Extensions:
Shock Extensions:
Even cut your stock links in half and extend them:
Details can be found here:
Oscar's No Build Thread - DIY Budget Boost:
https://wayalife.com/showpost.php?p=1024241
Bump....
Shock Extensions:
Very cool [emoji1360]
Delrin Door Hinge Liners:
If you have access to an engine lathe, then door liners should be at the top of your DIY list.
Start with some 3/4” Dia. Delrin Rod. Turn the OD to .522” +/-.001” x 1 7/16” back. Drill 11.5mm or 29/64” x 1 1/2” deep. Break all sharp corners with a file and cut-off using a parting tool to 1 1/2” overall length (1/16” flange thickness). Chamfer the bore on the cut-off end and install.
This mod cost me zero dollars since I already had the material and took about 4hrs to do all 4 doors including the removal of the old liners:
Nice, definitely a to-do (gonna have to buy them though)
Bumping one of my favorite threads...
Backup Camera - Adding one no longer requires a trip to the dealership to activate the backup camera function within the ECU. This can be done on the cheap with the new OBD JScan app for iOS or Android, a WiFi or Bluetooth OBDII Adapter and a smart phone. Hardware consists of the camera of your choice, harness for the 430 series head unit, RCA Coupler, assorted electrical connectors, tape and wire ties. This can easily be done for less then $100 and takes about 4hrs if you’re handy:
More detail can be found here:
https://wayalife.com/showpost.php?p=1121162
Backup Camera - Adding one no longer requires a trip to the dealership to activate the backup camera function within the ECU. This can be done on the cheap with the new OBD JScan app for iOS or Android, a WiFi or Bluetooth OBDII Adapter and a cell phone. Hardware consists of the camera of your choice, harness for the 430 series head unit, RCA Coupler, assorted electrical connectors, tape and wire ties. This can easily be done for less then $100 and takes about 4hrs if you’re handy:
Will it work with the 730N?
I believe so. The JScan app “activates” the ECU for the backup camera option, no matter the head unit. If I remember right the 730N is the same as the 430N with the exception of traffic updates. The back of the head unit should be the same and it should have an empty receptacle for the wire harness. I would double check it or do a little more research just to make sure that you order the right harness.
Nicely done! Very clean install
Wow missed this thread when I built my rear tire carrier and bumper a year or two ago. It was cool seeing what members have pulled off through the years. Some great projects. Seeings how its still making rounds, this was a fun build for me.20190315_074248.jpeg20190315_074412.jpeg20190315_074435.jpg20190315_074459.jpeg20190315_074602.jpeg20190315_074637.jpeg
Sent from my SM-G965U using WAYALIFE mobile app
Wow missed this thread when I built my rear tire carrier and bumper a year or two ago. It was cool seeing what members have pulled off through the years. Some great projects. Seeings how its still making rounds, this was a fun build for me.View attachment 323000View attachment 323001View attachment 323002View attachment 323003View attachment 323004View attachment 323005
Nice. What that a kit or did you fab it all from scratch?
Let's see homemade or DIY mods...
Title says it all. I want to see what modifications/creations/fabrications ya'll have come up with on your own. I'm looking for ideas I can "borrow".
Thread bump....
We’ve all seen the JK Front Bumper Chop, but I haven’t seen many using Rough Country Metal End Caps like I did here:
I think it’s a little nicer looking than the plastic caps and a ton better than nothing at all.
Installation was typical. Measure, tape and cut with a Sawsall. Touch up the metal ends with paint, mount cap, drill holes and push in the included fasteners:
I was concerned that the caps might wobble around especially since they are heavier metal and fastened with plastic push pins. To my surprise they are pretty sturdy although I will submit that they are purely cosmetic. Normally, I wouldn’t spend $100 on something like this, but I love the look of the integrated winch and think that this modification enhances the look.
Thread bump....
That really turned out nice. [emoji106]
2015 JKUR AEV JK350
1985 CJ8 Scrambler
