What did Brown Santa show up with today..
The last part on my most recent order finally arrived. A heavy duty steering box brace which moves the box forward 1.25 inches. When I get the new frame, the company said they would mount the front spring brackets forward by that same measurement. The shackles stay mounted in the same place and will lean a bit more forward at the bottom, but I have the wiggle room as now they sit slightly negative and should end up where I want them to be.
The CJ factory set up has the wheels set too far to the rear and causes rubbing and turning issues when larger tires are added. (At least the sizes I'm running).
I was going to do a heavy duty bracket anyhow so getting this style was a no brainer. Luckily, the rear tire sits pretty centered in the wells, only had the common issue with the front.
Yup, did exactly that with my frame build, along with a shackle reversal and pushed the axle mount forward by an inch up front on the springs. Back is pretty centered in the wells.
Progress!!
Brown santa has been busy here
We have JL hood latches for the JK
PSC big bore steering box
Shocks and spacers for the JL
LoD bumper for the JL
4+1 37-13.50-17 Cooper STT Pros for my JK
Rock Hard transmission cross member
Going to be busy getting all this installed.
