I took another look at the DRL and found that I did change the setting yesterday. I didn’t see the change because I had the parking brake on, so thanks to BaddestCross for the heads up on that!
I choose the “Turn Signal DRL” and found that the front signal light is very bright, just like when the signal if flashing.
DRL:
I thought it would be more like the parking light brightness.
Parking light:
I guess it makes sense that you would want the light to be brighter and more visible for safety, but can the bulb handle the additional amps on a continuous basis? I guess time will tell.
This DRL mode also turns on the tail lights. The side marker lights remain off, so maybe having a “parking light” option that would add the side marker lights would be a better approach?
If I have bulb problems, I will ask the developer to look into the parking light possibility.
