ARB Dual Onboard Air Compressor
Wrangler_Flash
Has anyone been able to mount an ARB dual (or single) air compressor underneath the hood of the 2018 JL? I know they said there is limited room underneath and I've seen a bracket for installing it inside the vehicle, but I'm wanting to install one under the hood. Anyone done this? 2018 JLU Rubicon.
Thanks
Thanks
I moved your post, to the JL Wrangler, sub forum. Hopefully you’ll find an answer, there.
This bracket is not for the engine bay install. From the sellers website - "With very little space under the hood of the JL, we moved the the ARB CKMTA12 Dual air compressor inside the vehicle. The mounting bracket locates the compressor behind the rear driver seat."
Do you know if this will work for the single compressor under the seat??
Been scratching my head on this one for a while. Under the brake booster is a maybe, but will definitely need a bracket made. The fender is all thin plastic under there.
