WJCO's Build Thread, 1999 WJ
I have been happy with my IRO springs. My wife even commented on them after installing. I hope yours serve you well sir. Love this Jeep.
Sent from my VS988 using WAYALIFE mobile app
Very happy with the ride. It was exactly the ride I was hoping for. The Zone springs were the same height as the IRO ones when I sat them next to each other. I took before and after measurements and lost 1/4" so no big deal. The ride is way better.
Zone on left and IRO on right:
Out of curiosity, now that you have been running the ARB breather kit for a while. How is it working? Would you recommend it, now that you've had it?
I'm liking it. I've gone through a fair amount of deep water since doing it and fluid levels are all still the same, so I'm really thinking that it works.
Hey - I lost track - do you still have the overheating going on or did you get that solved?
Still there but not showing itself this time of year. In June, I'm going to bypass the heater core because it is leaking and see if the symptom goes away. If it's still there, I'm putting a radiator in it.
Thanks, guys. Color is Rust-Oleum Cobalt Blue Metallic. I used it on my tie rod and drag link and it does hold up well as long as it is clear coated. Without the clear, I found it flaking off really easily. Since using clear coat, no issues.
The springs look great. Did you use a spray can clear as well and what kind of prep is needed?
Thanks. I sanded the coils lightly with 120. Then wiped them off with acetone. Then spray canned 3 coats of base. Then 2 coats of gloss clear. Pretty easy and fast.
Got my new Core4x4 track bar in. This thing is beautiful. Just by contacting them, they built this thing fully custom for me based on my custom axle application. The dual Johnny joints are custom, the length is custom, and the bends are custom. Can't wait to install it. I've had really good luck with this company as far as quality and customer service.
