Moochie
Crossing the line there now
Jeep porn.
Jeep porn.
But yours fits in most, if not all.![]()
On the WAYALIFE YouTube channel there is a 3 part series on the Rubicon and I believe part two shows the recovery of a 4 door that flopped on the side. You can see how to use the snatch block and dual winches. Also on the 2014 JKX part 2 or 3 there is a recovery of a 4 door JK that flopped on the passenger side. In the 2011 JKX in Carnage Canyon you can see Moby being winched up. There are several other video's that show how to use your winch.
R/
Will
Here's shot of the kind of hook I used to have on my old TJ and wish I still had.
Mine, and it works fine. So far, (knock on wood) has worked with all D-rings.
Looks like a good size, looks like both ends of a strap would fit on it.
LOL!! Honestly, it bugs me to no end how Factor55 tries to scare people into thinking that they somehow need their overpriced piece of billet aluminum with photos like this.
NOBODY I know does this!! No less than you would with a Factor55 thimble, all you need to do is connect both ends of your tree strap on a D-ring and then connect ANY standard hook that comes with your winch to it. Here is a shot that I took of how it can also be done using a snatch strap. Now, just imagine a hook in place of the snatch block - it's the same thing.
Even with the hook I showed, I would still do what you see above especially if there's a chance others may need to use the same winch point.
I used to work in the rigging industry...
...manufacturing winch lines, tow/snatch straps, tow ropes, and we sold all sorts of hooks, shackles etc, so I figure I could shed a little extra light.
The hook you have pictured above, and exactly what comes with 99% of winches is really an inadequate part. They are no way meant for any type of rope, synthetic or wire. They are cheap grade 30 or 40 hooks for chain, hence the Clevis style, it's really meant to hook into a chain link there. The grade 30 items are classified as general purpose items, farm use or personal kind of stuff. They're not even rated for tie downs, never mind lifting.
Well, in the post you quoted from WOL, I did in fact state that I realize tons of people use the hooks provided without issue. I did not say that everyone should run out and change their hooks because they're going to spontaneously rip apart either, nor am I claiming to be an expert.
I am saying that they are not the correct item for the application. Yes, they work. Is there an item manufactured that better suits the winching application? Yes. You posted the picture of the self locking hook, which is safer, manufactured to a higher standard, and suits the application.
I'm not trying to get into an argument, I'm not trying to scare people, and I'm not telling anyone what to do. Just trying to share first hand knowledge that I have from my time there.
They work. Is there an item manufactured that better suits the winching application? Yes. You posted the picture of the self locking hook, which is safer, manufactured to a higher standard, and suits the application.
In your previous post you said the hook pictured is inadequate but now you are saying the hook is safer and suits the application. Which one is it?
Are you an engineer by chance?
The hook provided with most winches is not the application the hook was intended for.
I have seen the aftermath of rigging equipment failing, and it can be deadly and gruesome.
Really guys, just trying to share knowledge. You can dismiss me as incompetent if you wish, or take what info you want from it.
Volunteer Fire Fighter Dies After Being Struck by a Shackle on a Recoiling Tow Rope – South Dakota
SUMMARY
On April 8, 2006, a 38-year-old male volunteer fire fighter (the victim) was struck by a shackle on a recoiling tow rope and died three days later. The fire department was dispatched to a controlled burn that had escaped its boundaries. Fire fighters arrived on the scene, extinguished the fire, and started departing the scene. An engine was being driven out of a soybean field when it became stuck in the mud. An attempt was made to tow the engine from the field using a tractor, tow rope and screw-type shackles on either end of the tow rope attached to the tractor and engine. With the victim sitting in the driver’s seat of the engine and another fire fighter sitting in the passenger’s seat, a farmer started moving the tractor forward. When tension was applied to the tow rope, the shackle on the tractor failed and the tow rope with it’s shackle attached recoiled toward the engine. The shackle smashed through the windshield, struck the victim in the forehead and then proceeded out through the back window. Other fire fighters, standing in the area, witnessed the incident and ran to the aid of the victim and called for Emergency Medical Services (EMS). The victim was transported by ambulance to the local hospital and then was air lifted to a metropolitan trauma center. The victim died three days later on April 11, 2006, due to the injuries he sustained in the incident.
So when mjay says failed hook I think of this.
Btw is says through his forehead and out the back window
http://www.cdc.gov/niosh/fire/reports/face200622.html
Thoughts on this
http://www.warn.com/truck/accessories/premium_winch_hook.shtml
