cozdude
Guy with a Red 2-Door
Yes, and with less calories.
That's impressive!
Love my Walkers and their new rims are suppose to be stronger, but those damn bolts are the weak point.
I bet the slab rings are twice the thickness
Can anyone chime in on the DD question? Mines not my DD but my wheeling trips involve driving from PA out west. A set of bead locks is on my hit list but
what's the streetability like on these? Balancing issues?
Anyone using the Chamber Pro II Beadlocks with 40" Nitto trail grapplers?
Having issues with the extra thick bead and sealing so no air leaks or brakeing bolts?
Soacers needed for the ring?
Thanks
Thanks
Has anyone looked at the Walker Evans Short Course Rings that are supposed to be thicker?
Yes they are installed correctly and per Allied tq'd to 25lbs, done this 3 times now. Never had leaks in 20 years of running beadlocks but the Nittos have a very thick bead even thicker than the MTR hence having to run the spacers.
I also have OMF beadlocks with MTR's and they use 3 spacers per OMF and no leaks.
Both Allied and OMF require spacers if the Alumnum ring bends or doesn't seat on the rim.
Here's a picture of my chambers and nitto 40's. That's how tight they are and don't leak.
Thanks, I assume that the ring isn't tilted in any..IE take a flat bar and place it against the face of the ring so it is at 12 and 6. The ring should be flat so you are not side loading the bolt heads. This will cause them to break-crack.
Picture is the spare tire without the ring shims, its tight like your picture and never leaks, same for the rear tires were before the shims.
I only broke the front rim bolts never the rears, guess from cornering loads.
Now as stated with shims, rings are flat no bolt breaking but leaks air.
If your rings are flat then looks like I'm selling my Allieds and getting new Chambers..
