Where to install accessory fuse block 2021 3.6L
JR-G
I am installing some lights etc. I know I have 4 accessory switches and wiring for these. (Rubicon)
These 4 wouldn't be enough, I need min. 6 cct. for now.
If nothing else would like the fuse block for termination point and expansion.
Ideally would located next to the battery and existing fuse block but I don't see anywhere to fit in small fuse block.
I don't see anywhere under the hood to install small six, eight or twelve fuse block.
Any recommendations or other solutions?
RCC
Cb bar ok
Switches $$$$600
But I bet they work dam good!
The price is probably higher than some options. With this system there are no fuses or relays to buy and all of the connections are under the hood.
Jay Ellyou
Rough Country MLC 6 Installed in a RHD JLU Sport , gives you six accessory switches all wired to the relay module under the bonnet, makes things really easy to wire up once installed
