fiend
Looks good.
If you turn it around and put the cap on the left it is easier to fill, and get a siphon hose to transfer with. That's way easier than dealing with the damn CARB spouts.
Good idea Jerry. I had that siphon system with my Trail Trekker, which I can’t use with the Genright carrier. I still have the hose though.
See you Monday?
BaddestCross
So far I've patched up the giant crack in her driver's side exhaust manifold, replaced one bad spark plug, fixed a couple plug wires, and put a couple heat shield sleeves on the same.
Getting ready for a camping run this weekend, I hope to get the new front hydro bump stops installed, the rock light wiring repaired, race radio antenna cable replaced, chase lights swapped out, and a new rack installed across the bed. We'll see if any of that actually gets done. [emoji23]
shogun
STTpro 37s, 4.88s, locker, ultimate44
Got a crazy good deal on an ultimate44 with an Eaton elock and 4.88. got some 37"sttpros and did the rear with trutrac and 4.88s. used that new app to do all the ratios. Got the doetsch tie and drag going on this weekend. Hopefully up to rausch after the break-in.
45caljeep
New warn 9.5 cti winch with synthetic sypdura line ... looks so different with the old warn power plant off
4.88s went in along with bombshell covers. Got to hang out with some great guys while the work was being done and see some nice rigs compared to what's usually driving around these parts... favorite was the one with the entire b pillar of roll cage actually being the air tank. 20190803_174843.jpg
Sent from my SM-G975U using WAYALIFE mobile app
Bear_JT
I was having issues with the rear defroster light flashing almost every time I would turn the key. Replaced my controls with these. Damn light still flashes once in a while but fan seems to blow stronger. Just gotta figure out the flashing light. IMG_7261.jpg
pop2tu
After watching Bust part #4 I decided I needed to put this leaking axle seal the priority for the weekend.
Cutting off the collar. Word of caution, it is real soft, cut off wheel cuts quick.
Cutting off the old inner race.
Pressing on new bearing and collar
I didn’t take any other pictures it was starting to get late.
MSJKU11
New hood latches
New rear sway bar links-thanks desertrunner
Got c gussets and front lower control arm skids welded. Not the best looking welds. 20190815_210801.jpg 20190815_190125.jpg 20190815_190157.jpg 20190815_172137.jpg
Sent from my SM-G965U using Tapatalk
OverlanderJK
Resident Smartass
Maintenance day.
Oil change, tire rotation, cut the body where it’s rubbing, wash and retorque.
Never go wheeling in Alaska. Three years later....
And the PCV change didn’t hold. Looks like a new motor is coming soon. Only 500 miles since the change.
benatc1
Maintenance day.
Dang that sucks about your fix not holding. What caused the body to that? Just all the shit in there?
Brute
