Looks good! What lights did you use?
These: http://www.superbrightleds.com/moreinfo/led-wired-bolts/plm-series-wired-one-and-half-watt-led/1141/
I went with the "Cool White" (6000k) in the flood pattern They had a slightly higher Lumen rating over the other colors and I intend to add blue accents to the Jeep as the budget permits. These were the most cost effective solution I've seen. Time will tell how they hold up. The quality seemed good (although they are made in China) I can tell you that you need to make sure the adhesive is pressed onto the light well; it was a little loose on a few. (Still real sticky, but not fully installed). It is the adhesive that is the likely weak link. I figured at this price it was worth a shot and I could always upgrade it if needed.
The light output is really pretty good. My picture doesn't do the front and rear justice do to the bumpers. (I seriously thought about leaving the valance off as it looked so much better.) But I put it on to play the need for a new bumper a little better. :brows:
