What is the/a crawl ratio?
JKU EXTREME
What is the/a crawl ratio? And what is the purpose behind it? I've never quite understood it. If someone could help me out with that, that would be great.
Thanks
-John W.
First gear in the 6-speed is 4.46
The 4-speed auto is 2.80 (and you can get a RubiCrawler too)
I don't know about the new 5-speed auto
Multiply your transmissions first gear x transfercase ratio x axle ratio = crawl ratio.
Example for an auto:
2.84 (1st gear) x 4.0 (transfercase gear) x 4.10 (axle ratio) = 46.576 crawl ratio
A higher ratio means your tires will keep trying to spin even when up against something. For example, in mall crawling, 2wd or 4wd might not be enough to get over a parking curb. When you shift to 4-lo, you can likely idle over it or it will require very little throttle. Go try it out.
PS on an auto, the crawl ratio is higher than the hand calculated method due to the torque converter.
Sent from a a few tin cans and some string.
