dpetersen1988
Hey guys i'm looking to see were everyone mounts there compressor and how they mount it, im thinking of welding up a custom bracket or seeing if i can make it with some metal brackets i found.
Harder to run wiring and air lockers though. Mines under the passenger seat and to have a clean install, it looks like I have to cut the major wires with the fuses to pass the wires through the fire wall, then solder back together.
Negatory. Run it through one of the drain plugs in the passenger footwell & along the frame up then up on the firewall. No cutting /soldering required. Unless you plan on deep sea Jeep driving you won't have leak issues. If you really wanted you could goop up the plug hole with silicone around the wires.
If you're interested, the whole install sequence is here - look at post 103.
https://wayalife.com/showthread.php/31355-The-build-re-build-of-Gruff/page11
