Andy5160
When wife wants something you have to comply
Let’s see if it gets me closer to that JL [emoji23][emoji23][emoji23]
Sweet - you found Chanterelles!
Y'know, JL's are often used to hunt mushrooms in their natural habitat. :yup:
Depending on which type you’re hunting, they can fund your new JL too [emoji13]
Not cooking it yet. Any suggestions on prepping/cooking this ribeye roast. I have a couple ideas floating. But also reading lots of options online....high initial temp then low. Sear first vs no sear, etc etc. Any go tos out there??
It’s about 10.5 lbs if that makes a difference.
Yup start hot and finish cool. You could sear it or just start with a super hot oven before knocking it down to 350. It essentially locks the moisture in the meat like searing it would. Cook for about 25 minutes on a super high heat(450 or so) if you don’t sear it before hand and then 16 minutes per pound after that at 350.
Make some slits in the meat and shove some garlic down in there. Then rub the outside with a blend of fresh thyme, rosemary, sage, salt, and peppercorns that you pulverize in a spice grinder or mortar and pestle. I like to cook mine with a shallow pan of dry red wine as well and make a rack out of aromatics such as carrots and onions and celery and fresh herbs.
Alternatively you could take the same herb mixture and add in some minced garlic, and lemon juice and mix it with a few sticks of soft unsalted butter to make an amazing herb butter to spread on the outside.
Getting my yearly dose of culture with the gf’s family
I’ll be Big Green Egging mine. It’s salted, peppered and drying out in the fridge.
View attachment 317289.
What's the plan of attack in the Egg?
This is my go to...never fail rib roast recipe...every step is important...
Let rib roast sit out of fridge 1 full hour at room temp.
Preheat oven to 375
Season heavily with coarse sea salt and fresh ground black pepper....place on roasting pan fat cap side up
Put in oven at 375 for exactly one hour...then turn oven off and leave in oven for exactly 3 more hours...it is IMPERATIVE that the oven door is not opened during this time
Remove from oven, place on a large cutting board and tent with foil...let rest for 30 minutes before carving.
I've made my rib roast this way for three decades...comes out perfectly between rare & medium rare every time...
Preheat oven to 375
