Vibration in front end
robx251
So I have a vibration on my front end I know it isn’t death wobble. It is some sort of harmonic vibration that starts when I go over a bump effect as small as the breaks in the road like going over a bridge and it goes away when I engage 4WD. Then when I disengage 4WD it is normal until I hit another bump. Thoughts?
TrailHunter
It could be a lot of things... I’d probably start here to see if there is a change:
1. rotate tires
2. Remove the steering stabilizer, and hit some bumps to see if you get death wobble
3. Remove stabalizer & disconnect the front sway bar to see if you get Death wobble
4. Remove front drive shaft
robx251
1. rotate tires
1 not a tire vibration
2 it’s not death wobble
3 it’s not death wobble
4 the front drive shaft in a JL does not turn where it has the FAD on the front axle plus it goes away when 4wd is engaged which would cause it to turn
the vibration is a high frequency harmonic that seems like it’s one of the split shafts spinning out of balance
TrailHunter
4 the front drive shaft in a JL does not turn where it has the FAD on the front axle plus it goes aww when 4wd is engaged which would cause it to turn
Gotcha... bad u joint?
TrailHunter
Those Felt good and it just passed a state inspection
Vibrations are frustrating... I feel your pain.. I chased one on my GMC for months that I could have sworn was coming from the front of the truck... and ended up being the rear driveshaft.
robx251
Thanks. I could only imagine that it is the front where it doesn't change when under acceleration or deceleration or coasting when in 2wd only changes when in 4wd.
robx251
After looking at some of the information on replacement parts online from Quadratec and a few other places it appears that there is a nylon bushing that goes into the end of one shaft that has a pin from the other shaft in to it. My guess is that this bushing is worn out. and when the FAD is connected it eliminates that slop in the bushing by the collar engaging both shafts.
TrailHunter
Hope thats it. 👍🏽
