Uncontrollable sway on highway
Update.
So I went wheeling up in Naches last weekend. A weird issue I encountered. Going around some corners on the drive up my ESC was kicking on. Not even pushing it. No tires squeeling and turns were hard but not very hard. Turn the corner and the brake pedal would vibrate and lights flash on the dash.
After this occurred 3 or 4 times I pushed the button to turn the ESC off, went wheeling for the day. Reactivated it at the end of the day and the issue disappeared. It took breaking tires loose around corners on dirt roads before it would come back on. It seems fine again.
I rotated the tires yesterday checked ball joints and steering. Everything was tight.
I did toe out the tires a little as they were toe in a little too much and left the tire pressure down around 30PSI. That actually cut down the flighty feeling quite a bit.
